Re: Brake adjustment
Posted by FBH44 on September 04, 2013 at 09:56:20 from (64.85.217.170):
In Reply to: Brake adjustment posted by BigTone on September 03, 2013 at 13:45:39:
This might help, might not; IF the "M" is like the "H", you first loosen the locknut on the bottom of the brake housing, then tighten up the square-head screw til the brake band touches the brake drum, then loosen it down 3/4 turn or so. Tighten back up the locknut. Do both sides. Then you check to see how much free travel the brake pedal has to touch the tramsission case. You are looking for 1 1/2" free travel or so. Remove the cotter pin and the pin, and screw in/out / up/down the top clevis, until you get it right, reinstall pin and cotter pin. YOu have to have the brakes pull evenly at speed; go down the road with them latched together, put on brakes, and she should pull straight ahead, NOT right or left. Readjust as necessary. THis is the "H" procedure, and by golly, it might work on the "M" too.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
