Re: Stuck bolts....ideas?
Posted by mkirsch on September 04, 2013 at 13:05:16 from (64.80.110.74):
In Reply to: Stuck bolts....ideas? posted by joshua rod on September 04, 2013 at 10:25:17:
Small torch = propane torch?
Save it for sweating pipes or making S'mores.
You need something that can get the bolts red hot. Whatever torch you use needs an oxygen tank at minimum.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
