Re: Stuck bolts....ideas?
Posted by ken house on September 04, 2013 at 14:14:04 from (173.242.240.212):
In Reply to: Stuck bolts....ideas? posted by joshua rod on September 04, 2013 at 10:25:17:
a 50-50 mix of acetone and transmission fluid has been proven to be tops in penetrating oil. it will not store long, so keep it in a bottle that you can close.
also, when you go to slide the wheels, turn the wheel so that the solid piece is on top, jack the tractor so that the wheel is going to slide down grade, towards where you wish for it to go. makes life easier. p s , oil the axle before you try to slide wheel.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
