Re: thoughts and ideas
Posted by Janicholson on September 04, 2013 at 16:13:05 from (74.60.94.18):
In Reply to: thoughts and ideas posted by Ed in Pa on September 04, 2013 at 15:50:57:
Put 8000ft (High Altitude) pistons in it, with the thin sleeves to give it a bigger bore. Use a 350 intake and carb, and a 350 cam . Run the timing ahead to 30 degrees total or find the sweet spot on a dyno.(use 93octane fuel) Remove the belly pump, belt pulley, and PTO. Use a small 12 v battery and no generator (constant loss, just keep it charged) remove the air cleaner and use a paper filter on the carb intake. Make a hitch to replace the U and drawbar. Put on brackets to allow hanging weights on it to make weight classes.
These modifications (and no filled tires can put it is a lower weight class) Be sure to follow the rules. Good luck, Jim
