Re: Stuck bolts....ideas?
Posted by Lmack on September 04, 2013 at 16:35:17 from (24.131.50.165):
In Reply to: Stuck bolts....ideas? posted by joshua rod on September 04, 2013 at 10:25:17:
Get a stronger bar and do not hold back. The bolts are 3/4 and the guy who put them on most likely used an impact wrench or a long bar. If you knew the order they were tightened it would help. The last one tightened is the easiest to break loose. When one is out the others will also break loose. Do use the oil and heat. Heat has to be applied both at the bolt head and at the wedge. Heat the bolts and move away and let the heat transfer to the entire length of the bolt. MUSEL up and make it move. I use a 4' length of 1 1/4" water pipe or more if needed.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
