Re: 560 Hydraulic Control valve
Posted by pete 23 on September 04, 2013 at 18:19:14 from (74.47.41.165):
In Reply to: 560 Hydraulic Control valve posted by bosscat28 on September 04, 2013 at 12:29:10:
There is no o-ring or seal that prevents leak down in that valve. It is a spool valve, metal to metal fit. You may have a check valve off of that valve. I will be a block either bolted under your valve or might be bolted to seat with hoses running in one side and out the other with plugs to take it apart. There are O-rings in there that will cause your problem.
