Re: Stuck bolts....ideas?
Posted by Lynn Kaufmann on September 04, 2013 at 19:46:12 from (76.84.124.37):
In Reply to: Stuck bolts....ideas? posted by joshua rod on September 04, 2013 at 10:25:17:
One more idea is to use heat and then spray some Deep Creep by Sea Foam on it when it is hot. It has worked well for me before. Sea Foam even advertizes it this way.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
