Re: Farmall H battery issues
Posted by gene bender on September 05, 2013 at 14:04:32 from (67.55.198.113):
In Reply to: Farmall H battery issues posted by Richard1974 on September 05, 2013 at 14:01:01:
ground the field that should make it charge if it doesent get the genny checked and if it doesent charge the reg or ground is bad somewhere
