Re: rusty gas tank
Posted by Griff NC on September 05, 2013 at 14:52:05 from (98.26.238.25):
In Reply to: Re: rusty gas tank posted by ken house on September 05, 2013 at 07:39:25:
I just cleaned out a 1953 cub tank . I found on here( Thanks guys ) where the use of Lye to clean one. I soaked mine twice and it got rib of the rush and varnish .
Cheap fix too .
I did once I had it clean , dry it and put in a gallon of wd 40 and shake it around to prevent it from flash rusting .
Use search function here on cleaning out gas tanks ..
