Re: rear tractor tire repair ????
Posted by rustred on September 05, 2013 at 15:12:36 from (74.200.18.155):
In Reply to: Re: rear tractor tire repair ???? posted by SDE on September 05, 2013 at 15:05:02:
so that must kinda put it in the centre side wall. kind of a bad spot due to the flexing. but use a patch that just covers the cut. then use a big one over top of that. should get you by for some time, long as not doing heavy pulling. keep the tire aired up to max will help.
