Re: rear tractor tire repair ????
Posted by Tom Fleming on September 05, 2013 at 17:27:25 from (67.20.233.75):
In Reply to: rear tractor tire repair ???? posted by SDE on September 05, 2013 at 14:33:09:
I have personally used the Gempler's tire liner to repair an 11" failure in an older 36" turkey foot tire, that I wanted to salvage because it was 1 of a matched pair for my F-20. I also bought the rubber repair epoxy from Alltire supply.
I am pleased with the result, and used the rubber epoxy to cover up/seal the opening after the liner was installed. I buffed the rough repair down to a reasonable blend into the original profile. While not perfect, it absolutely is not ugly either.
My only advice is, if you are planning to work this tire, I would watch it for awhile, but probably will be fine withl only a 2" gash. If this is a show only trailer queen, I am positive you will be fine.
Mine is a show tractor that I have no plans to use for antique pulls or similar. Parades only. so far, so good.
