Re: Frozen Spindle on Running Gear
Posted by Cole Younger on September 05, 2013 at 18:24:29 from (12.175.18.5):
In Reply to: Frozen Spindle on Running Gear posted by Wayne Rimathe on September 05, 2013 at 13:58:53:
I have done quite a few in the Blacksmith forge you need even heat all the way around tube and spindle will fall out on the ground. I never could get enough heat with the rosebud plus the coal fire doesn't make the metal brittle. After the spindle is out I hone the tube, polish spindle and grease really good and keep them greased so it don't happen again.
