Posted by Raner on September 05, 2013 at 19:08:59 from (173.175.94.231):
Hello All... I just got a 1949 Farmall-H... All the carb kits I've found are missing a gasket... I'm fixing to rebuilt carb, That's no biggie... The problem I'm having is that I can't find the gasket on the carburetor side for the governor actuator shaft housing that controls the carburetor butterfly...Hope I described it right... Does any one know the correct name for it and where I can find the gasket...
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
