Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Reversed Rims/tires???
Posted by Todd Markle on January 18, 1999 at 17:01:40:
In Reply to: Re: Re: Re: Re: Reversed Rims/tires??? posted by Deutsch on January 18, 1999 at 10:54:55:
He is talking about an implement that is powered
by pulling it (the turning of the wheels makes the implement run). As opposed to a pto driven machine. Most horse-drawn equipment worked this way (except if the implement had an engine mounted
on it). V-tread tires are also used on the rear
axle of modern self propelled combines. If the combine is 4 wheel drive, the tires are put on in the normal direction, if it is not 4wd then they are put on backwards. If you look at most tractor
tires, they have arrows on them. 1 will indicate
direction if it is a drive tire (normal direction)
the arrow going the opposite direction indicates
roll(non driving application).
Post a Followup
: Re: Re: Re: Re: Re: Re: Reversed Rims/tires???
