Re: rear tractor tire repair ????
Posted by Tom Fleming on September 06, 2013 at 03:09:02 from (67.20.233.75):
In Reply to: rear tractor tire repair ???? posted by SDE on September 05, 2013 at 14:33:09:
504-1, I have done similar repairs on a small cut, with good results. Remember, AG tires are NOT run at road speed (ie. 50-60 MPH). One has to use a little common sense on how big/bad the injury is, condition of the overall tire, intended use, etc.
Most tire shops don't want the liability of a failed repair, so they shy away from it, even if it is relatively simple and small.
IMHO.
