Re: 1958 IH Utility Bac khoe Runs (Barely) then quits
Posted by old on September 06, 2013 at 07:58:50 from (209.86.226.58):
In Reply to: 1958 IH Utility Bac khoe Runs (Barely) then quits posted by drizler on September 06, 2013 at 07:10:53:
What does the spark look like?? You need a blue/white spark that will jump a 1/ inch gap or more or it will not run as it should. Valves can not be the problem if the compression is good unless they are so loose they do not open up as they should but that is not likely.
