compression is good.??? what IS the actual compression readings? these engines are a cold blooded thing and till warmed up kid of like to stall. but they will start with just a push of the button. has to be something plugged in the carb. what does "went through the carb" mean? was it taken apart and soaked in carb cleaner, and all passages blown out with air? like pretty vague info to go on. also any old tractor i aquire gets the valves set to spec also, have found many with little clearance or else lots. that is part of a tune up. then i check compression and record readings. then you know if you can smile or use your second language .also the main jet on carb should be 4-5 turns out. maybe its just a carb adjustment?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
