Re: 1958 IH Utility Bac khoe Runs (Barely) then quits
Posted by mkirsch on September 06, 2013 at 11:45:31 from (64.80.110.75):
In Reply to: 1958 IH Utility Bac khoe Runs (Barely) then quits posted by drizler on September 06, 2013 at 07:10:53:
Yeah you can "assume" but you'd be surprised at how many "experienced" guys just "assume" the spark is good and don't bother to check it.
Without actual compression readings and actual spark status, there's really no ideas to float...
If the compression is anywhere near 90PSI it can be made to run. If the compression is even across the cylinders, it can run like a top with good power by simply tuning the carb and ignition.
Timing could be way off causing the bad running.
