Re: Hydraulic pressure of 48 H
Posted by gene bender on September 06, 2013 at 12:23:50 from (67.55.198.113):
In Reply to: Hydraulic pressure of 48 H posted by Farmallb on September 06, 2013 at 11:55:20:
Just dont pull the lift lever back too much. Is your sickle bar adjusted for lead so when its mowing the bar isnt running back thus running at an angle. And is the sickle in time so it makes a complete slide back and forth to allow make a good cut.
