I have replaed several cloths and some are spot welded on the two vertical bars die grinder to remove then i make new ones for replacing. Ifind i much easier with the 3/16 cloth to do it in two pieces overlaping in the middle before painting and use fiberglass resin to hold in place when its clean after sandblasting the resin will stick easy. I have a piece that i use to make the bends over the two vertical pieces then bend the tabs to hold fast takes some time .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
