Posted by rustred on September 07, 2013 at 15:20:45 from (74.200.18.155):
In Reply to: Re: Farmall M posted by JS Sleds on September 07, 2013 at 13:48:42:
yes, i use it on all my head gaskets and all other gaskets. it is tacky and holds gaskets in place. gaskets also come off easily too if you have to remove them. also its not like you got a bunch of goop squeezing out after torquing. i like the stuff and it works good. i have used it on a good many 282 diesel engines and not a seep, as these engines are a gasket tester i say.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
