Re: D-282 Engine Question
Posted by jle on September 07, 2013 at 16:26:04 from (70.194.0.251):
In Reply to: D-282 Engine Question posted by labman98 on September 07, 2013 at 07:53:50:
An old rule of thumb, was .001 per 1" dia of shaft. 2.5 main .0025 running clearance.
Had a W-9 in frame overhaul, had about 4.5 clearance, slipped .002 under size in got the old girl warmed up good running on dnyno, come to sudden stop, ended up putting standard brs in. One of those lessons you learn over the years.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
