Re: Lubricant for Steering Gear Compartment -Farmall H M
Posted by pete 23 on September 08, 2013 at 14:44:54 from (74.47.41.165):
In Reply to: Lubricant for Steering Gear Compartment -Farmall H M posted by Picklesmith on September 08, 2013 at 11:21:42:
The problem with using grease, even corn head grease, is it doesn't get down to the bushing below the gear, thus you end up with a worn bushing and scored shaft. IH later recommended the additive that was used in tractor transmissions with torque amplifier but that is no longer available. I use a liquid EP gear lube, 80-90, 140 or what ever.
