When you changed to 12 volt, did you change to negative ground? If so did you change polarity on coil? I have converted 2 tractors from 6 to 12 volts and had no problem at all. I like the 12 volts as I use the tractors at night and lights are easier to find in 12 than 6 volt and alternator keeps up better when running equipment that also has lights. You could have a points or condenser problem, sounds like it misses no matter what coil you use. On one of my conversions I used a resister ahead of the 6 volt coil for a long time and it worked fine, but resisters tend to burn out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
