Re: dual clutch question
Posted by AWJ on September 08, 2013 at 18:26:48 from (75.131.122.154):
In Reply to: dual clutch question posted by not8n on July 06, 2013 at 14:09:53:
A couple of yrs. ago I too purchased a 354. It had
been sitting for several yrs. It too had the clutch
stuck. with someone holding the petal down I struck
the disk with a prybar and hammer several times
through the inspection hole in the bottom and it
broke loose and works fine. good luck.
