A key switch works if you hook the alt #1 terminal to the ACC position on the switch. This puts separate voltage to the Alt when running and shuts off the connection when the key is off. (no connection to coil between the Acc and the Ign terminal on the Switch). The gap is .020" on the points. Use a meter on the coil input to assure 12v is present. 12v coils from cars usually need a resistor! Few are made as full 12v coils. So your substitute coils may Be equal to 6v coils. The coil should draw less than 4 amps when on and the engine stopped points closed. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
