Re: Re: No Start on my H
Posted by farmall man on December 01, 2000 at 08:34:07 from (209.156.74.13):
In Reply to: Re: No Start on my H posted by ltf in nc on November 30, 2000 at 16:38:23:
LTF, The procedure you describe is the way I set it up. It did not start. Regarding your statement "if it does not start rotate the distributor exactly 180 degrees and start the engine", I think I am a little confused, If I now rotate the distributor 180 degrees the rotor will now be aligned with the # four cylinder terminal in the distributor cap with the # 1 cylinder on TDC. Wouldn't the # four cylinder be on the exhaust stroke?
Post A Followup
: Re: Re: Re: No Start on my H
