Re: GM 10si Alternator Conversions
Posted by Dan Bear Kelley on September 09, 2013 at 09:58:11 from (140.32.120.188):
In Reply to: GM 10si Alternator Conversions posted by Dan Bear Kelley on September 07, 2013 at 09:18:07:
I agree, from one standpoint, it's expensive. My problem is I have so many projects, my time is worth quite a bit. And this is a nicely put together assembly. I can install this for 5 or 10 minutes and go back to my other projects.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
