Re: No Start on my H
Posted by Mike on December 01, 2000 at 08:55:46 from (24.93.177.194):
In Reply to: No Start on my H posted by farmall man on November 30, 2000 at 14:04:14:
I had the same problem with mine. You say you rebuilt the carb. Does gas run out the bottom of the carb when you stop cranking? If so, and if the float's not sticking or out of adjustment, you may have the wrong metering jet installed, or it may be missing or the top half, which does the metering, is broken off. This causes immediate flooding so bad that the plugs won't even fire. The top half of my metering jet had been broken off, probably on a previous rebuild. I drilled it out, retapped the port, installed a new metering jet and it fired right up with a fresh set of plugs. Other thoughts: Pull the air intake breather cap off, put the palm of your hand over the pipe and crank the engine. Does it develop vacuum?. If not, a leak between the carb and the manifold will cause such a lean mixture that no cylinders will fire. A leak between the manifold and the head will just cause that pair of cylinders not to fire. Are you getting a bright blue spark at the plug electrode? I saw you checked most everything, but a weak coil can cause this problem. Hope this helps.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
