Re: Farmall H Remote Control Valve
Posted by D Slater on September 10, 2013 at 04:54:06 from (184.14.163.227):
In Reply to: Farmall H Remote Control Valve posted by Fullern90 on September 10, 2013 at 03:48:40:
Valves are the same. If you get one from a M with fittings. Change the pipe nipple to 1 X 1 under the valve and put a 3/4 X 3 nipple in where the present 3-1/4 long fill pipe is. Those changes make it H size. But also the valve support straps on top are different. Best to get the special connection fittings with the valve. They can be installed without having the original fittings, but easier with.
