Re: 450 rings
Posted by D Slater on September 10, 2013 at 05:23:15 from (184.14.163.227):
In Reply to: 450 rings posted by rustyone on September 09, 2013 at 18:14:46:
You may be able to use the rings, but checking type and measuring should be done. M&W used some with 3/32 wide rings in the top 3 groves and a 1/4 oil control. Should be a number on the M&W piston. Replacing with a P&S set is always the best option if quality parts are used. But not sure where to find quality parts for these old engines anymore.
