Re: 404 Hyd oil
Posted by Janicholson on September 10, 2013 at 06:34:04 from (199.17.6.160):
In Reply to: Re: 404 Hyd oil posted by denwic on September 09, 2013 at 22:08:50:
A higher viscosity Hydraulic Transmission oil is available. Trying that first might be easiest and save money. Mobil has one as does Shell, and others. It is about 20W40 in viscosity, but your job is to find what you need. It is not a pure hydraulic oil, it needs to be compliant with gear lube (transmissions) Jim
