Re: Farmall H starter questions
Posted by kevinj54 on September 10, 2013 at 16:46:14 from (50.42.187.107):
In Reply to: Farmall H starter questions posted by Zachary Hoyt on September 09, 2013 at 19:05:17:
You need to spend some quality time with that meter. It should pretty easy to take a reading at each terminal while pressing the button and see which component is defective.
You want to take readings on the studs or battery terminals and on the connected wire terminal to be sure the connections are good.
I checked one for a guy at a show and we found bad connections, failed switch and a bad starter.
