Re: Farmall M. . .any differences?
Posted by D Slater on September 10, 2013 at 19:20:04 from (184.14.163.227):
In Reply to: Farmall M. . .any differences? posted by bigboreG on September 10, 2013 at 17:11:19:
42 came with a non pressure radiator, a engine block with some core plugs that can rust out and let coolant into the engine or leak out at the rear. Magneto was standard. Ignition drive housing has a different bolt pattern than a 51 and no seal for the driving shaft that a 51 has.
Distributor was standard on a 51 along with a voltage regulator for the charging system.
PTO were originally different. Several other changes.
Unless you get one of the near last M tractors built a 51 model was one of the best because IH made little upgrades through M production.
