Re: Farmall H 6 to 12v conversion
Posted by oldtanker on September 10, 2013 at 21:32:15 from (66.228.255.116):
In Reply to: Farmall H 6 to 12v conversion posted by Sako on September 08, 2013 at 16:09:11:
OK, Bob and Rusted both say to leave it 6 volt cause that's the way it was designed. So does that mean on an H or an M you should never, ever add live hydraulics, power steering or a3 point cause they were not designed that way? The guy ask a question about how his tractor was running now that the conversion is done.
12 volt to me is the way to go. I have 3 tractors that have been converted to 12 volt and I'm very happy with those conversions. All will start in MN winters at -15 or colder. 1st step in a conversion is to make sure the tractor runs as it should in 6 volt. That doesn't mean the charging system has to work but the battery has to be fully charged. If it isn't running right fix that problem first. You do not want the 12 conversion to be a Band-Aid. Sounds like you got a bad coil. It happens. As you were told check for shaft play on the distributor. Check point gap too. If the points are not clean and brite put in new points. Get good ones. The ones sold by TSC and other farm supply places may be of low quality. Same with the coil. Standard, Blue Streak and NAPA all see decent points and coils.
Rick
