Re: Farmall 656 gas
Posted by pete 23 on September 11, 2013 at 10:41:07 from (74.47.41.165):
In Reply to: Farmall 656 gas posted by Michael E. Poe on September 11, 2013 at 09:15:20:
The transmission and final drive case is the reservoir for the hydraulics. The pump or pumps if it has a three point hitch are on the left side where the hose and pipe come out of the mounting plate and go up to flow control valve and to rear hitch valves. Filter is on right side directly opposite of the pumps. It is an oval cover with six bolts. Has paper filter with screen bypass valve that opens when filter is restricted, like plugged or very cold oil. I would check oil level with dip stick and filter for crud. Uses hydraulic transmission fluid like IH hy-tran.
