Posted by John T on September 11, 2013 at 12:28:05 from (216.249.76.176):
In Reply to: lousy spark on an M posted by P and R Pete on September 11, 2013 at 10:56:49:
If its a 12 volt system, it only needs a voltage dropping (12 to 6) ballast resistor if you use a 6 volt coil. If its a 12 volt coil and you still use a ballast THE SPARK WILL BE WEAK.
If its a 12 volt tractor with a 6 volt coil + ballast and you by pass the ballast, the coil will overheat and the points burn up quickly.
I have seen ballast resistors go bad and that can cause a weak or no spark.
A common cause of a weak spark is the points are burned or pitted or mis gapped or maybe the condensor is bad. I prefer wire core copper plug wires versus carbon core resistive supressor wires like cars use
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
