Posted by old on September 11, 2013 at 13:27:04 from (209.86.226.40):
In Reply to: cub guys posted by Steve Bontrager on September 11, 2013 at 11:51:36:
A lot of times poor spark is blames on a carb which is just fine. So start by simple trouble shooting. The spark needs to be a blue/white in color and jump a 1/4 inch gap or more at ALL 4 plug wires. Then go to the carb and do a few checks. #1 pull the carb drain plug and make sure you have a good steady flow of gas for a few minutes. Catch it to look for water and dirt etc and so you can use it. Next if is is the type with out the adjustable main jet there is a cover plug over the main jet. Pull that plug and make sure you have a good flow of gas out if it. If you do not use some spray carb clean and spray the jet out with the drain plug out and that may fix it
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
