Re: Farmall H generator amperage
Posted by John T on September 12, 2013 at 05:51:55 from (216.249.76.176):
In Reply to: Farmall H generator amperage posted by redandgreen on September 11, 2013 at 20:13:23:
Good tips from Jim and Bob, here are a few other tid bits:
Sometimes carbon or oil or crud on the commutator causes weak charging, clean that commutator up see if that helps.
If the brushes are worn down too short or the hold down coil springys are weak, dirty or sticking that can reduce the charge, clean and exercise and light lube them
Insure the LHBD switch HAS A GOOD CLEAN FRAME CASE GROUND, try a jumper to insure then see if charge increases. As noted see how much she charges if you take a jumper and ground the gennys FLD post?? If its good then but weak otherwise, that tells you the genny and its brushes etc are all okay so the LHBD has a poor ground or is bad or the wires bad from FLD on genny up to the switch.
If the battery has a problem (have it load tested) even a good genny cant pump much charge into it ya know
John T
