Re: B275 pto stopped turning
Posted by JimB2 on September 12, 2013 at 13:25:04 from (99.241.76.141):
In Reply to: Re: B275 pto stopped turning posted by ShaneGreen on September 11, 2013 at 19:58:24:
Hi Shane, usually the little pin shears off item #4 so you cannot engage/disengage PTO.
JimB
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
