Re: incorrect factory rear tire size, red flag?
Posted by Janicholson on September 13, 2013 at 11:07:15 from (199.17.6.25):
In Reply to: Re: incorrect factory rear tire size, red flag? posted by pistons on September 12, 2013 at 14:26:20:
Loaded tractor with duals can break an axle by having the weight of the tractor and a lifted attachment load the axla when driven over a rock or bump on the outed tires only. The traction can be an issue in lower gears causing reduced shock protection and stressed gears and bearings. Good sense, no problem. Jim
