Posted by IH fan on September 13, 2013 at 11:07:06 from (174.70.169.139):
In Reply to: New To Me 1966 IH 504 posted by Florida 504 on September 12, 2013 at 18:24:15:
First of all, no the fluid is not supposed to be white like that.... it has water in it. You will need to flush it really good, kerosene or diesel works, and still probably not get ALL the water out the first change. Next, if you had enough pressure to operate the bucket and 3 point strongly and blow that line, there is nothing wrong with that pump or the master relief valve. Since you have a 3 point, you have a double pump, but the main can be either a 12 or 17 gpm. There MAY be a circuit relief valve in the main loader valve, but I don't know. If there is a circuit relief, that could be your problem with lifting with the main boom. Or it could be your cylinder seals are bad and are by-passing inside the cylinder. Beyond that, someone more familiar with the 504/2504 will have to answer, but I'm thinking your loader has it's own set of valves and your disconnects to the loader are some kind of "pressure-beyond" ports from your auxiliary valve, and not actually operated thru that valve..
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
