Re: Pistons stuck in sleeves...suggestions?
Posted by farm-al on September 14, 2013 at 05:43:46 from (66.43.233.9):
In Reply to: Re: Pistons stuck in sleeves...suggestions? posted by CharlieNJ on September 13, 2013 at 18:12:41:
As usual every one has their opinion which is great,I guess mine would be on the side of saving a piece of Farmall history if you can,I have had the same issue with stuck S&P,s and I soaked them in alcohol for a while befor trying to press them apart,even common rubbing alcohol will work,it will cut or soften the rust,Al
