Re: 184 Cub Lo Boy Coolant pressure....
Posted by John M on September 14, 2013 at 07:03:48 from (209.213.28.157):
In Reply to: 184 Cub Lo Boy Coolant pressure.... posted by IHMANKY on September 13, 2013 at 17:43:34:
One side, don't remember which, of the hose is bigger in diameter than the other end. (I think the rad side is a bigger OD than the gooseneck side. If he got a hose with the same ID on each end, it will blow the gooseneck end off. Otherwise, Is make sure the whole cooling system is clean outside and in, and the fan belt is tight. May need a new cap as well.
