Farmall Tractors Discussion Board
Re: Re: Re: Help! H Hydraulics not working.
Posted by Bob on January 18, 1999 at 17:36:09:
In Reply to: Re: Re: Help! H Hydraulics not working. posted by C.Fitz on January 18, 1999 at 14:09:51:
The hyd. pump on an H is relitively simple in design. It only has two moving parts. If you need to remove it after finding no pressure at the outlet,drop the inspect. plate and see if the coupling is turning. There is also a lever on the belly towards the rear of the tractor that enables you to disengage the pump. This lever is held in position by a capscrew that threads into the belly.It may be that it is just shut off.
Post a Followup
: Re: Re: Re: Re: Help! H Hydraulics not working.
