Re: Pistons stuck in sleeves...suggestions?
Posted by Tom Fleming on September 14, 2013 at 10:36:13 from (67.20.233.75):
In Reply to: Pistons stuck in sleeves...suggestions? posted by Blackriver on September 13, 2013 at 16:47:40:
Thanks Gene, I may take you up on that. Let's see what Blackriver wants to do. If I can help the young man out, I am happy to. Either way, I am putting together a C-113 display. I have everything for the conversion that came in the kit, except a good set of pistons. The ones I have were given to me, but the skirts are broken on a couple due to the way they were removed from the sleeves.
Gene, I don't' have nearly the inventory or experience you do on these, but I have enough C-113 parts to probably put together 4-5 gas versions.......just missing a decent set of the early distillate pistons.
