Posted by pete 23 on September 14, 2013 at 15:43:49 from (74.47.41.165):
In Reply to: 666 International posted by Glenn Weeks on September 14, 2013 at 10:39:22:
The hitch has it's own separate pump, mounted piggy back on main pump. Also, separate relief valve under cover under seat. Procedure to test pump is in book but a little complicated to tell from here. Several different things from pump, relief valve, leak at valve, unloading valve could be causing problem. If I didn't have gauges and fittings to test I would pull plate off under seat and look for obvious leaks, but be careful as it could shoot oil all over. Also, you can hold aux valve on demand and see if it lifts better when doing that. If it does problem is in unloading valve in draft control valve.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
