Re: Farmall M Magneto
Posted by Bob M on September 14, 2013 at 16:16:40 from (69.207.87.207):
In Reply to: Farmall M Magneto posted by Two Banger on September 14, 2013 at 15:55:04:
TB'er - The magneto is completely independent of the rest of the electrical system. Hence it has no ground polarity (pos or neg ground).
The only external wiring to the mag is to screw on the side - grounding this screw kills the spark which shuts down the engine.
Sparking from the solenoid when you turn the key is either a loose power connection at the solenoid, or the solenoid itself has worn out.
