Re: International D-239 injection pump problem
Posted by Kelly MT on September 14, 2013 at 21:07:55 from (216.14.249.188):
In Reply to: International D-239 injection pump problem posted by douglas Grandy on September 10, 2013 at 00:33:41:
Check the mechanical shut down lever on the side of the pump. See if it looks like it has moved (rotated) on the splines. Also see if the lock wires are still in place on the stop screws. If not, have they been moved? The adjustment is very small from fuel to no fuel. I rebuilt my pump and lost the index of lever to shaft. It took some time to find the right spot again. This is a pretty simple pump to dissemble and check out and re-seal. Seal kit is about $30. PK
