The felt ring is for the water pump to seal between the pulley and the pump.
The original seal was felt with a retainer and leather with the lip facing forward. You will not find any replacement parts like that. All you will get is the spring loaded lip type seal. Just install it so it is on an unworn part of the pulley.
The original seal is installed lip forward to keep dirt from being blow past it from the fan blast. I always install the new style seal with the lip to the oil side. If you install it like the original you run the risk of the spring rusting apart and releasing the tension on the seal lip.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
